My shift solenoid went bad and only had 3/4th gear so i just replaced both A and B and i try to drive the vehicle and its like super sluggish. In reverse i have to hold the rpms at like 2500 for a sec for it to start to even slowly move... any ideas?
Since you loaded the parts canon already and shoved parts into the unit, and got no good changes, you're not gonna like the next part at all!
Worst case? ----> you might have an internal cross-leak that's constantly feeding the forward clutches.
More good news - worst case situation though ---> you've prolly got a cracked input housing, or cracked forward piston which welds the forward clutches together.​
> Revving it in Reverse is a big clue here..... - you are needing to break the forward clutches loose that are welded together so you can force it into moving backwards.​
Get thee to a shop.
