1 - 11 of 11 Posts
i found two servo upgrades 2nd and 4th gear what the difference between the two and can/could these be used together. need a lil help before i buy either one!!!!
the 1-2 shift in these vehicles is the sloppy one, get the 1-2 corvette servo, its the one everyone on here gets, noone needs a firm shift going into overdrive thats the exact opposite of performance
The 1-2 is the worst shift, the 2-3 is naturally firm.
You dont need a hard 3-4 shift because noone is winding out third gear and shifting into overdrive at 130mph, its all low speed, low throttle stuff
Question
Don't have a tune, can't because of warrenty. Just want to clean up/firm up the shifts. Not looking to chirp the tires and what not. Is the Vette 1>2 servo and the .490 all I'm going to need?
That's a good start. You might also want to replace the plastic accumulators with pin-less aluminum versions while you are in there. They replace without pulling the valve body and can eliminate some issues down the road with sloppy shifts.
so if we are just lookin to firm up shifting not neck snappin (due to the 8 month old in the back seat) would the 1-2 servo, and a .490 boost be enought?
That combo in my Trailblazer shifts smooth and quick at part throttle. But at WOT it hits hard and will squeak the belt. I just put in the regular aluminum accumulators, not the pinless ones.
1 - 11 of 11 Posts
