1 - 3 of 3 Posts
I have a 2002 Chev Trailblazer LTZ i was wanting to see about replacing the Radio/CD unit with a Radio/CD/satellite Radio unit. Are other units from later models compatible or would it be easier to just do a ext install of a satellite radio unit ie hooking it up using the current radio and cigerette lighter throw the magnet antenna out the window etc etc. :undecided
if you are looking for ease of install yea the ext set up is the way togo. you can use a wired tape and put it in the tape deck which gives you better sound then using the fm transmitter but if you want better sound find a radio with it already. you will probably need to buy the module though either xm or sirius. and hide it somewhere behind the radio up under the dash.
1 - 3 of 3 Posts
