1 - 9 of 9 Posts
Instead of running all new speaker wire...is it okay to run directly from the amp to the metra harness, as long as the speaker wires are not connected to the head unit at all?
Also if I already have a single amp and want to add a 4 channel, I just need a distribution block correct to splice the power cable correct?
Thanks.
This is what i'm currently running.
http://www.mtx.com/caraudio/products/amplifiers/thunder3401.cfm
http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-K4
I'm trying to add this amp.
http://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-6404
Should I be okay with the 80amp inline fuse that I already have? the kenwood is 25 and the mtx is 50...am i doing this right even?
I have no audio experience, and i've done enough searching to where I think I have everything figured out...but still want to double check.
1 - 9 of 9 Posts
