1 - 3 of 3 Posts
Hello all im kind of new to the forum so sorry if i do something wrong.
But i have done countless research on this and cant seem to find an answer :worried:
I have a 2004 chevy trailblazer lt 6 cyl
So when i start the truck it seems to rev up to around 1300 rpm
and as i let it warmup it idles down to around 600
but if i dnt let it warm up and just take off the rpm gauge reads at around 2000 rpm
but it sounds as if it were at around 4000 and the truck doesnt really move im guessing because its still in 1st shift? not sure
as well if i leave it o for a while in park the rpm will start to decrease and itll rev up to 1200 on its own and back down to almost zero til it turns off eventually, but not long after i had found that the gas filter was leaking so in replaced it the issue is still there it just doesnt turn off anymore.
sorry its so long but i really have no clue as to whats going on or where to start looking. Thanks in dvance for all help!:)
I actually cleaned the throttle body about a month ago and it just fixed the rpm from going up and down it still started at 1300 though
But up until maybe a couple days back is when i noticed it again
I also added some seafoam cleaner into the gas tank to se if that would help
All it did was fix the gas wasting problem not the rpm
I have read before that thatsmiqht be what im hearing but i quee i wont kno until i try it
But still what could be causing the rpm to just qo down to about 300 then automatically rev back up to 1300 n just keep doing that until it evwntually turns off?
1 - 3 of 3 Posts
