1 - 6 of 6 Posts
2004 chevy trailblazer_lt_ext
Cruise Control engaged at 45 mph Flat straight roadway.
Tachometer fluctuating between 1200 and 1500 with engine responding with tach movement.
And no codes!!
WTF???
Although the speed is different this sounds like trouble with the Torque Converter Clutch lock-up system.
I have the same problem as you. I read somewhere someone had the same problem. It was their vvt seloniod. I habe one on the way now shoild be here today. I will update you later tonight if that was the problem or not. Really interested if that is the problem. Been fighting this for a few months now.
Sent from my LML713DL using Tapatalk
Discussion Starter #4
Just put one in. Didn't change the rpm fluctuation.
I think im going to change the transmission oil filter next. I did get a code for about a day a few months back that was for transmission component failure. But went away the next day.
1 - 6 of 6 Posts
