1 - 6 of 6 Posts
2003 gmc envoy 4.2l i6
So I have a gmc envoy and when I start it up in the morning It used to have a super rough idle it would vibrate the car really bad does anyone know how to fix this
What do you mean "used to have a rough idle"? Does it still have that? Is the Check Engine light on, have you checked for codes? If you increase RPMs, does rough running stop? Need more info.
It does but it is not as bad if i increase throttle it goes away but it is only when I’m in drive and I’m stopped it has a rough idle and the check engine light is not on and it does not have any codes that I know of
Probably want to check the motor mounts, worn motor mounts can cause vibration at idle. Another thing to do is clean the throttle body front and back sides.
basic thing is to check spark plugs, check history when was the last time it was replaced?
2005 isuzu ascender
I just got done replacing my timing chain. Before that I had a rough idle due to the spark timing being off, along with the cams. You do not want to replace the timing chain, trust me. But if your Envoy only does it when you first start it up, you may have a throttle body issue.
1 - 6 of 6 Posts
