05 tb ls my ride is running inconsistent I cleaned the throttle body I put in a new air filter clutch fan water pump theirs no vacume leaks but if I reset my computer it runs fine for a rew hours then it starts acting up again until i reset it again what do i do next? Maybe coils Idk thats the only thing i can think of someone help please
Is Check Engine light on? Have you checked for fault codes with a scan tool? This information is needed to start a diagnosis.
Well it was running fine and I took it to the car wash and washed under the hood with the car on and drove it home and it started acting up after that I checked the code it said it was my clutch fan so I replaced it with a new one and water pump as well and it's still acting up I went to check again a little but ago and I had no power to the wire harness so I'm about to go check my fuses but I'll let keep you posted thank you
Since it was running fine before the car wash, I would check for water in the spark plug wells.
