21 - 23 of 23 Posts
Has anyone removed and replaced the right cv axle seal outside the differential? Is the removal procedure for the right cv axle seal the same as that for the left (driver side) seal? Can you just pull the seal from the outside after removing the axle?
My right front CV axle inside boot tore. It was caused by the outer bearing in the disconnect housing going bad. I removed the CV axle by tapping it out after removing everything in the way as you already did and then unbolted the actuator and then unbolted the disconnect housing. The outer bearing comes with the new disconnect housing. Bolt in the new disconnect housing, reattach the actuator and then push in, may have to tap in, the new CV axle and you are done.
21 - 23 of 23 Posts
