1 - 20 of 22 Posts
I'm planning on losing the res. how long of a piece of pipe do I need to get and what diameter? I have a stock '03'Trailblazer LS 4.2L. I would like to have come out behind the wheel if possible, that should not make things to difficult right?
2004 chevy trailblazer_ls_ext
They used a 2.5" piece that slides nice inside the stock 2.75" piece. Not sure how long, depends on where you want it to exit.
chevy
I've been contemplating this mod. I however want the new pipe to fit over the left over pipe, instead of into it.
2005 chevy trailblazer_ls_ext
yeah you want the pipe to fit over the leftover pipe from the exhaust. if you get a pipe to go inside of the old pipe their will be a lot of backpressure. thier will be a lot of poping when letting off the gas pedel.
I don't know what other members have experenced but my pipe is on the inside and I don't have any popping sounds. I agree that a 3 in pipe on the outside might be better but my setup works ok. See my gallery for pics. Jay:m2:
so you think that a 2.5" pipe going inside a 2.75" AFTER you remove the resonator is gonna be too much backpressure?:weird:
I've said this on other threads: TV's do not have mandrel bent exhaust pipes. If you look at the pipe where it goes over the axle (at least on my Envoy) it is so constricted it looks more like a 2" pipe. Even the resonator is crimped down at the inlet and outlet. If you want the bigger pipe for looks, go for it. But the 2.5" inside the 2.75" will not cause any extra back pressure. :m2: The res itself is a straight flow through and causes no pressure.
i do aloota work on imports [honda/acuras] and obv theres no comparison with our tv's but for those motors backpressure is good bp=tq...wouldnt this still apply to our low end numbers givin us a stronger low end tq numbaahs :undecided
The I-6 does seem to run better with some back pressure. :thumbsup: I'm just saying going to the 2.5" pipe IMO won't increase the back pressure.
Back pressure is a necessity for our motors to optimize power. I ran straight piping for a while, and although the sound was great, power was lacking. As soon as I put my dynomax on, power greatly improved. I did get very quiet, so I recently cut the res. off and it now sounds about as good as I think these motors can without being too ricey.
No, the pipe being slid inside the other one has nothing to do with the popping sound you hear from the exhaust. The popping is a result of the camshaft overlap. The popping is there from stock, but you just don't hear it much with the muffler and resonator installed.
Will the resonator replacement pipe being inside the other one cause any more back pressure??? Yes, but the amount is so small I wouldn't worry about it.
As mentioned above, these engines do require some back pressure to develop low and mid-range torque, so whatever you do, don't remove the muffler or use a very low restriction replacement :nono:.....the stock muffler is pretty free-flowing as is.
no you said there would be alot of backpressure. read your post.
yeah i said there would be backpressure that would make the poping sound and thats what one of my uncles said and thought was right but it might be wrong but i thought that the poping sound was made by the backpressure and i guess he was wrong telling me that and didnt mean to say something that wasnt right i was just going by what my uncle said, next time i wont listen to him!
hii,..
does the resonator delete give more power to the engine on a 6 cyl?????
and how does it sound without the res. ????????????????????????????/:undecided:undecided
1 - 20 of 22 Posts
