I wonder if you can help, my daughter just bought a 2004 Envoy and we have since found that the DIC is not working!! Should have checked more thouroughly!! I got some Techie help and have so far confirmed that the wiring to and from the steering wheel is sound, I have +12v at the lower steering wheel connector (on the appropriate pin outs) that drops to ground when the steering wheel buttons are pushed. I am now advised that the problem is internal to the cluster and it probably needs replacing? I have read several threads here about adding the DIC function but few if any, mention whether the cluster had to be re-programmed and what was involved in doing that? I am told you CAN NOT re-program a Cluster from a wreck so you should buy a Refurb and then do the install at the dealers as you may not be able to star the vehicle until the re-pro is completed.
ANY IDEAS on my best next step and what is reality when it comes to replacing the cluster?
:bonk:
