21 - 40 of 108 Posts
Sorry to hear your fuel cap comes off. I read earlier of some tsb's and repairs but have gotten used to filling on slow for my last estimated 2 gallons to prevent fuel burp and gas smell.
I concur, nice write up. [begin sarcasm] I sure am glad GM didn't make it too difficult to change out the thermostat. [/end sarcasm] :laugh:
Changed Thermostat...now no air comes out of dash vents aghhh!!
Hey! Love the strap idea! I invested in a set of gear wrenches after that bottom alternator bolt stumped me. Soo...now I have another problem. I took my battery completely out (to get more working room) for the thermostat replacement...now, I'm not getting any air flow out of my dash vents (which sucks!) Any thoughts / solutions would be much appreciated!!:confused:
See previous post regarding computer tender, it is not uncommon. You may be lucky and only a reset of the computer is needed, but it seems many have had to replace the actuators. I don't know if someone has found a better answer but I would make sure ac and defrost are off before I reset the computer. I might even run it a day or so with them off. Let us know how it works, and search the other posts possibly for a better answer.
Discussion Starter · #30 ·
Thanks for the responses everyone! I am glad the write-up was helpful.
Since posting this, I am now just shy of 180K and no other problems so far. I did not have any issues with A/C or anthing else after replacing the thermostat, so unfortunately I can't help with any of that. My next expense will be new tires this weekend. I could not be happier with my TB!
2004 chevy trailblazer_ls_ext
Thermostat replacement 2004 TB Ext
Well, armed with the photos and the knowledge provided by this forum we tackled the thermostat and other things on my TB. 5 hours later the thermostat was done. My dad used to say engineers should be shot if they can't design a machine that can be fixed easily. Well folks whoever designed this system needs shot! The bolts to the thermostat were easy to take out through the fender, but the alternator had to come out to get the hose off. To do that you have to remove 3 5mm bolts that are 6-7" long. BUT on the EXT the transmission cooling line and air conditioning lines are in the way and the bottom bolt is a bitch to remove and re-install. Not to mention that we spent an hour looking for a lost bolt and socket that fell because everything is so tight.
This looks to be a project in the near future for me. My Envoy threw the check engine light at me yesterday, so I took it to the local Advanced and, while they didn't tell which codes they were, he told me what they meant. Either low coolant (there was plenty in the reservoir) or the thermostat was on it's last leg.
Any parts houses I need to stay away from?
Do the Censor too!
Advanced, who is so cagy they won't tell you the code. :confused:
Code readers can be cheap, and I recommend everybody (or group of friends) has one. If you have an Android phone, the low-cost Torque app can run with a $20 bluetooth obdii transmitter.
Don't have a cell, but I would like to have a code reader.
I finally got my t-stat in about an hour ago. Make sure you check to make sure your new one has a check valve(?), 'cause mine didn't. Had to go back and get another one.
Starting this job tonight, hopefully with this article it will make the job a little easier......great idea on using the wratchet strap for the AC line! :yes:
2003 trailblazer_lt
Any link to this item? very interested.
EZ Red ms4000 - works great but only works through obd2
http://www.amazon.com/Z-EZRMS4000-Automotive-Presets-Computer/dp/B000J4JCL0
OTC 3177A - more versatile with the obd2 connector as well a cig lighter adapter for pre obd2 vehicles - note: this one blew the adapters cig lighter fuse two times (even though key off/timed out load was under 5A in each case)...the first time I lost a half hour getting a GM vehicle to relearn idle, the second time I lost about the same getting a radio code from my local honda dealer
http://www.amazon.com/OTC-3177A-Professional-Memory-Saver/dp/B004FZ9FWK
OK so just finished mine last night, wasn't as bad as I thought it was going to be.....only a scrapped thumb :duh: I found a trick that worked for me with the bottom thrird bolt, I took a smaller sized 18mm wrench and side a rowing moting in between the fan flades. Took the top two bolts off first and it was able to lean the alt forward and wiggle it out once the bolt was unscrewed. It alos made it easy to keep the bolt in the alt and then move it out enough past the AC lines to pull it out completely....same thing in reverse for install, place the bottom bolt in first, then lide it down into the engine bay....
