Hi all, need some reinforcement/direction. I have a 06 V8 Envoy that had the DOD lifter failure. I replaced the lifters with new ones on the passenger side and the truck runs great. After driving a few miles, the car will overheat and coolant will pour out the bottom of the truck. I can't tell where it's coming from because the whole engine area is covered with coolant. Also the oil pressure is dropping to 0 forcing me to shut the truck off. I have only had the truck a few months and only drove it 100 miles before the lifter failure. No issues before that.
I'm assuming I did something wrong when I replaced the lifters. My guess is that I didn't tighten the cylinder head enough (I had no degree gauge and was paranoid about breaking a bolt). I think that could cause my overheating issue. What about the oil pressure? Would a non-sealing head gasket cause oil pressure loss?
I'm tearing the motor apart again. Should I use copper spray on the head gaskets this time to be extra sure it will seal? I'm going to buy new bolts and a degree gauge this time. Anything else I should look for?
