1 - 9 of 9 Posts
Does anyone know how to get to the foglights on a 2002 GMC Envoy? i need to change the passenger side, but don't know how.
You have to reach from underneath and twist out the bulb then pull straight out
Are you talking about the bulb, or the lense? If your talking about the lense its just 3-10mm's and then you pull it straight out. Can easily be done by reaching behind.
Replacing the bulb is easy, just stick your head under the bumper and you can easily remove it.
Replacing the whole assembly with OEM can be a bit difficult, especially when the bolt spins with the nut, but can be done with some patience. I had to take of my bumper cover to do mine.
Replacing the whole assembly with an after market is even more difficult. The recess isn't very deep, and will involve cutting on the bumper and a bit of JB weld.
Is there an amber replacement bulb I could use on a TB? Always preferred amber fog lights to help pierce through the haze, and it'd be nice if there were a direct replacement.
1 - 9 of 9 Posts
