1 - 6 of 6 Posts
I have an 05 and Im thinking about removing the side mouldings. I used to work at a body shop and I remember some cars have small holes in the door where tabs on the back of the moulding go. I just want to make sure if I take the mouldings off my TB there aren't going to be any little holes. Are our TB's side mouldings only glued on with 2 sided tape?
future reference use the search button on the top...only double sided tape...check my galery for before and after
The molding removal looks great! Did you just hit it with a heat gun to facilitate removal?
welcome!
i actually used a hairdryer to loosen it up. i started from the front side of the peice just enoguh to pull back the corner. once it was loosened, i slid some fishing line behind just to loosen it a little further so that i could fit my hand to grip it, then i just pulled!
rinse and repeat
it left a slight glue residue from where it was, i just took one of those big 3rd grader pinky eraser and rubbed it out. then washed and waxed and its good to go.
any more questions let me kno :thumbsup:
1 - 6 of 6 Posts
