Is there a way to Remove the intake fan and the shroud without removing the fan clutch assembly?
You can loosen the fan blade assembly from the clutch, just a matter of four bolts, however the center is smaller than the clutch assembly and cannot physically be removed without removing the clutch from the pump. <sorry>
The only way it may be possible is if the radiator could be removed through the front and then you might be ale to manipulate the fan and shroud through the opening........I've never tried it.
