1 - 6 of 6 Posts
hey i was wondering if you can remove the mid level trim pieces on the doors to make it look more like the ss
Yep u sure can! its held on there with a double sided tape from the factory....easiest way to get it off is get yourself a piece of fishing line and use a sawing motion inbetween the molding and the body..it comes off very very easy!!..The hardest part is getting the residue off the body when your done,,i found that goo-gone works the best!:thumbsup::thumbsup:
yep,,once you clean it off you'll never know it was ever there.
Hair dryer and a credit card. Get it real worm, slide credit card behind molding to get it started once you pull a little back get heat behind the molding and carefully pull. Use finger to roll back sticky tape backing, clean with bug tar. compound and wax.
1 - 6 of 6 Posts
