I have a viper 5101 remote starter installed. Lock work through xk01 module. Remote start will activate, but the starter never engages. i checked for voltage on the purple starter wire and i did find voltage after the remote start becomes active, so there is voltage going through the starter wire. The weird thing when the remote start engages it shows as driver 3 on the dash, the security light does not come on so I think the security is bypassed. Please help.
2003 gmc envoy_sle
Have you programmed it? I recently installed a Viper 5900 and when I first attempted to start it with the remote it, it wouldn't work. I had to start the Voy first, and "learn" the remote start. I also have the XK01 and it should default to the programming for the Envoy. Just make sure the first set or series only blinks once. I'm not sure if this helps at all, just sharing the problem I encountered.
