thanks! Went to a trans shop that did road test said that the 2-3 shift is a little soft but everything is normal. Reset the TAPS and bring it back if issues continue. No trans code present. Just getting ready to possibly have to rebuild trans.
That the shift to Direct/3rd is soft - is really a harbinger of failure.
Remember that NO clutches slip during use --- never. They are harsher than you would believe unless you could somehow eliminate the torque convertor for a clutch and flywheel.
I can do this on my K5 with a THM700R4 because I have the torque convertor electrical apply on a rocker switch that I can call in or out as I see fit.
BUT ---- if I leave it IN (engaged) and let it shift normally -- you can lose your back teeth --- it shifts THAT hard!
If you abuse the clutches at all - they die if they spin. You might get away with it for a while but no outside programming or re-profiling shift points is going to repair the damage --- and believe me -- there is damage.
Water and fertilize your 10-dollar tree in the back yard so you get a big enough harvest to get your unit rebuilt to higher standards --- then YOU have a mitigating hand in how it will work and perform.
