2003 chevy trailblazer_ltz
My 03 t blazer has a rear wiper that is loose and floppy .Not sure how to remove it to see what's wrong with it.The motor runs but it only moves up and down about 8 in.?
pull the plastic cover off the attaching nut, and make sure nut is tight. If you are lucky, you did not strip the shaft. You will need to realign the blade in the parked position.
While its off, lubricate the pivot point so that the spring will apply good pressure to the glass. I use pb blaster to loosen it up, and then some white lithium grease to keep it free for a while.
