1 - 7 of 7 Posts
I have a 2002 Envoy SLE 4x4 with a rear air ride suspension.....I found some rear coil springs for a 2002 Trailblazer....will they work? And how would I bypass my compressor so it will still work in the hatch if wanted to still use it for pumping things up?......anybody?
the air springs/bags just twist out after deflating.
You could just plug the outlet at the compressor that goes to the bags.
would pulling the fuse allow it to work via the switch in the back? If so then gravy. If not, some wiring will take care of that.
Ok, so if I still want to use the compressor I could just plug the line that goes to the bags and I will still be able to use it?
1 - 7 of 7 Posts
