1 - 7 of 7 Posts
You have a dozen cement blocks in the back on the pass. side?
Deteriorating springs or they came that way from the factory. You can add a donut-shaped shim under the low side rear spring, assuming it's only the rear. Have you parked on a super flat surface and measured all four wheel well opening heights?
Bad but obligatory joke: Your wife is fibbing when she says she's still 104 pounds.
shes 110 but yeah the rear dr is 34" pass is 33 1/2" and both fronts measure 32 1/2 to the bottom of the fender. where do i find 1/2" block?
Do you have rear springs? Or the air suspension? The two sides can be adjusted separately with the air.
1 - 7 of 7 Posts
