1 - 9 of 9 Posts
Having problems with my 02 TB LTZ. The rear latch along with the rear windshield wiper will not work. When I use the remote to click unlock all 4 doors respond by unlocking (usually the rear latch as well) but its not. I also noticed that after turning off the ignition the radio turns off right away instead of staying on until opening doors..
do all of these things have a common problem? Looking for any help or advice..thanks!
when my rear door and wiper weren't working, i had to unlock the door from the inside and pull the rear interior panel off. then all i had to do was push the electrical connector back into it's socket, it had come loose, about the radio i have no idea. good luck.
The issue I have is that the wiper fluid (windex) doesn't come out from my outlet like it should. I hear it working, but then the fluid just somehow accumulates on the bottom where the rear door latches onto the car.
Similar to the other issues - first you have to gain access to the inside of the liftgate by taking off the panel. Then find where your washer fluid tubing is disconnected or broken inside.
1 - 9 of 9 Posts
