I have a 2008 Trailblazer LT. The rear hatch door will not open. It seems the latch is not releasing when you pull the handle. I watched a YouTube video and saw how to remove that plastic plug and manually open the door, which I did. I then took the inner door panel off and tried to see what the problem was. The latch looks as if it's operating correctly but I'm not positive. So do y'all think it's the latch or the unlocking mechanism associated with the key fob? When you press the unlock button on the fob, it sounds like it's working but the door won't open.
Sent from my SM-N950U using Tapatalk
2005 gmc trailblazer_ls
Had this problem in my Envoy turned out to be a bad actuator.
Sent from my SM-G955U using Tapatalk
