1 - 16 of 16 Posts
2006 chevy trailblazer_ss_ls
Hello everyone:D I have a 04 TB Ext with a 5.3L V-8. Love the truck except for one issue::mad: It has a misfire when cold or hot. CEL code PO300. Which is a random mis-fire. Truck has almost 90,000 miles and has been maintained religiously. Has new A/C delco plugs and wires,new intake manifold gasket, new fuel filter and air filter. I have cleaned the throttle body and did a BG fuel system service. Replaced ignition parts twice in last three months. Also replaced two coils even though they specd out fine. I am at wits end:(. Any help would be appreciated. Thanks in advance!
I forgot to mention that when I did the intake gaskets I did replace the cam sensor and crank sensor. I will try the map sensor. Thank you. Will keep you informed to see if that take care of problem:thx
Did map sensor. No change:hopeless I'm close to getting a match. Any ideas would be appreciated:thx
check the EGR valve (Exhaust Gas Recirculation Valve).
The I-6 does not use a EGR valve. OOPS, I cannot read, you have the v-8 sorry......
2007 chevy trailblazer_lt
coil packs
known problem for coil packs to short out....maybe a wire (spark plug wire) touching???
try to see which cylinder is missfiring....a scan tool will tell you....
Don
Finally the problem got worse and was easier to find. Had to replace Throttle Body Assembly and gasket. Not bad found a reman unit with lifetime warranty for $160.00 at O'Reilly Auto. Easy repair to do. My truck is back:woohoo: Thanks guys for all your advice:thx:grouphug:
After I made sure its was not a spark problem, I checked around intake and throttle body and vaccum hoses using B-12 spray with engine running. The idle changed around the throttle body. That was my problem a simple vaccum leak.
Thank you, I'll try the same with my TB.
I've read the throttle body gaskets on the 5300's are crap, at least in the early 2000's. Apparently GM's released a "new" and "updated" gasket. Coil pack fixed the issue I had with my 5300, even though it was showing "random/multiple cylinder misfire". A code reader with real-time misfire data is invaluable.
1 - 16 of 16 Posts
