1 - 13 of 13 Posts
I'm not sure if all the trailblazers have this but the 05 the radio stays on until you open the door. If i was to stay in the car for like half an hour (girlfriend never gets out on time) is it bad to leave the radio light and dash lights on. At first it was like sweet the radio stays on then it was like wow now i look like an idiot opening my door to turn the radio off lol.
All trailvoys have a ~20 minute reserve power to the radio after you turn off the ignition so you don't have to have the key in the acessory position to listen to the radio while you are waiting in the vehicle for some reason. You can just shut off the radio by pushing in the top rotary volume switch.
All Chevrolets have this feature, it's called RAP (Retained Accessory Power).
Discussion Starter #6
after like ten minutes i usually open the door
I assume its just as bad as leaving your car in auxiliary. I mean you can turn the radio off but all the dash lights are on they probably don't pull that much power but I'm sure its bad for your battery.
2009 non_gmt360 other
No, it won't hurt anything. I've done it before where the 15 (or 20) minutes ran down and it shut itself off. So I turned the key back to on (but didn't start the car) and took the key back out. It's only the radio and dash lights, so it won't drain the battery that quickly. You can always kill the dash lights, thats what I do.
i left my stereo running for like 2 hours before and never had a problem, starting the truck.....so i don't thin you'll have a problem with the RAP......
i did have the HL's off tho....
It doesn't work like that, the Class 2 communication tells the radio when to turn on/off.
2009 chevy
Yep, it's always hot, it (radio) and a lot of other electrics.
The retained power feature is a programming function; after a length of time (based upon a complex logarithm) the class 2 bus commands the devices to sleep. A couple of the electrics (dumb ones) are controlled by a relay that simulates the software commanded sleep function, the smart ones are bus controlled.
1 - 13 of 13 Posts
