Question for the pros! help needed.
1872 Views 9 Replies 3 Participants Last post by  bigmike_123
I need some professional help about hooking up my alpine 10" DVC (4ohm) sub to a Kenwood KAC-8104D amp. I'm confused because this is the amp I might by however I can't figure out why it has 2 woofer connection terminals. I want to hook my sub using 1 speaker wire at 2 ohms amp load. I see other amps have just one speaker terminal. Can you tell me what the difference is and how would I connect my sub if the amp has 2 seperate terminals. :undecided
1 - 10 of 10 Posts
the outputs positives and negatives are internally bridged for an easier connection when hooking up 2 coils
just wire both 4 ohm coils in the enclosure, and have 1 lead form the amp go to it
fyi my RF Power amps are setup the same way
the link below is the owners manual for the amp. look at page 4 for the wiring setup. hope this answers your question
http://akamaipix.crutchfield.com/Manuals/113/113KAC8104.PDF
fyi my RF Power amps are setup the same way[/QUOTE
So if I understand correctly I just have to wire 1 wire +/- to the amp that will be wire to a 2 ohm load and this will give me the full power?
Why do the create mono amps with 2 sets of speaker terminals? Is that so you can hook up each coil on the sub ( like a 2ohm DVC sub) to each terminal?
yes....keep in mind you will have to parallel the coils inside the enclosure to get that 2 ohm load
yup....I use 8 gauge wire for my subs, and it would be tough to cram 2 leads into one terminal
Thanks for your help. Cheers :)
Word:cool:
post pics when your done
we loves pics:D
I have some pictures posted in the picture section thread. Should be the last one. I'd like to hear your comments.
Cheers :)
Thanks man, it sure took along time. But it turned out pretty nice and tight. I can hardly wait to get an amp hooked up to it. I'm itching to hear it. I'm pickin up an Alpine MRP-M500 from a guy tomorrow. So it should be real soon. chow for now.
1 - 10 of 10 Posts
