1 - 15 of 15 Posts
2004 isuzu ascender
I have a 2004 chevy trailblazer and my head unit is a pioneer deck 50x4. My stock front door speakers work fine. But my back seat speakers dont, so I tried to replace them and the first new speaker I installed in is not working. I then checked behind the deck and all wires appear to be fine I even touched them some to see if something was lose. I checked a few fuses below my back seat but I am running out of options.
Has anyone else had this problem if so please let me know how to get my rear speakers working PLEASE? please call
Cory 918-269-9133
sounds like either a damaged wiring harness, or a faulty amp in your deck. Connect the speaker directly to the deck with some new speaker wire. If you get sound, it's a harness issue, at some point between the deck and rear speaker. If you don't get sound, your deck needs to be repaired/replaced -- and you need to consider the possibility of a short as the cause.
2003 trailblazer_lt
1 - do you have the bose system?
2 - do you have or have access to a DMM?
2008 chevy trailblazer_lt
Have you tried connecting the old speaker or a diffrent speaker to see if any sound comes out of them. Maybe the problem is the new speaker. What brand speakers are you trying to install?
2003 trailblazer_lt
I do not have a bose system and no I dont have access to a DMM.
No, my deck is not faded all the way to the front.
Has anyone had this problem before?
Assuming that the new speakers are good, more then likely there is an open in the wiring between the head unit and each of the rear speakers. A DMM would help track down the fault. A few cases of broken wires in the door jam harnesses have been reported.
2008 chevy
Can you get to the back of the radio and directly connect a speaker to the wire coming out of the radio, just use a short piece of speaker wire.
This would at least let you know if there is a problem with the radio or the wiring.
Frank
P.S. I did have the fader all the way to the front problem once.
so did everyone on the site get the same PM twice from this guy or was it just me?
"" Rear door speaker problem
Hey, I have a question for you.
Cory Steward
918-269-9133
[email protected] ""
Cory Steward
918-269-9133
i got it too
1 - 15 of 15 Posts
