1 - 7 of 7 Posts
I have a 2002 Trailblazer, and it locks out all power and the key gets stuck when trying to start the engine. I can turn the key to accessory and on and everything works (radio plays, lights/gauges come on), but when I try start to the engine there is one click and then everything turns off (no power at all; locks, horn, lights, etc). Then the ignition will only turn as far back as accessory, and it will not release the key.
If I disconnect and reconnect the battery all power returns, and the key is released (turns back to off). After doing this the vehicle will start sometimes, and run like normal. But after sitting for an extended period of time (overnight) it will go back to the same problem.
I have checked all the fuses already, but don't know what else to check.
1 - 7 of 7 Posts
