A few days ago our left turn signal started doing the double frequency flash as if a bulb is out.
Things that I can see
1.right turn signal flashes as normal inside, outside front and rear.
2.left turn signal flashes double speed inside, outside rear, but is not flashing the front left.
Things that I have tried is
1.replacing the left front bulb that is not flashing - no changes
2.tested the bulb socket and I'm not getting any power to the turn signal but I do have power to the running lights that share the same bulb.
3.checked the fuses and they were all good.
The only ideas I have are
1.replacing the turn/hazard/towing module GM#12450184
2.replace the tail light distribution boards
I really hate throwing parts at my vehicles hoping to fix an issue so if you have had a similar problem or any ideas they would be greatly appreciated.
Thanks, Fred
Thanks, Fred
