1 - 10 of 10 Posts
I just installed a new thermostat without removing the alternator.In the process I broke an electrical plug in near the thermostat. The wires still look attached but I'm not sure what they run to.
I didn't notice anything funny till today. When I was leaving work I heard a weird squeeling noise from the drivers front just as I hit about 10mph.I heard the sound twice then it went away.
Anybody have ideas what this plug in runs to?
Here is a pic of the pigtail that I broke.
is there enought wire to solder it back together? thats what i did on the 2wire connector for the alt.
I think I might need a new sensor....the wires are all still connected to the pigtail but it looks broken fo sho. lol I'll try to take some better pics tomorrow during the day.
I took some more pics this morning....
General area...
Zooming in on the sensor.....
Coolant temp sensor maybe????? Any ideas??
Here is a pic looking up at it from underneath....
From this angle you can see the whole plastic head of the sensor has broke off from the metal.
Any ideas????
New idea.... High pressure cut off switch for the A/C. :duh:
That would explain the squeeling sound I heard. :D
Well it turns out it was a high pressure cut off switch for the A/C. $40 from auto zone and 15 minutes to change out. Didnt lose any freon in the process either. :D
Do you still have the pics for the high pressure cutoff switch? I think mine went bad but I don't know where it is located. My compressor doesn't shut off when there is too much pressure causing refrigerant to blow out. Also, any info on changing it would be helpful.
There is a low pressure switch on the dryer/receiver, towards the passenger fender side. Item 32 in the drawing. GM #89040362 ACDelco #15-50156
The high pressure cutoff isn't a switch, it's a sensor. At 350 PSI the PCM disables the compressor clutch, and re-enables it at 229 PSI. This sensor is on the piping coming out of the compressor. Item #22. GM #22664328 ACDelco #15-5742
Both of them unscrew without needing to recover the refrigerant. Two of the few DIY items in the AC system.
1 - 10 of 10 Posts
