1 - 8 of 8 Posts
I'm getting ready to go on a road trip and put about 2000 miles on my 05 TB. I just had it in for a service and check 500 or so miles ago. My question is there anything else i might want to consider doing before or even during my trip. Plan on using the cruise control alot. Any tips appreciated.
Thanks!
....edit #1 .. I just have over 48,000 miles on it as well.
Check your spare, bring extra windshield washer fluid, bring and extra quart of oil or two *just in case*, make sure you have all your tire changing equipment, jumper cables, bring a gallon or two of water just to have, ummm, I know theres something I am forgeting.
Gallon of antifreeze. Also, if you have 3.42 gears, you might want to watch the cruise control on very hilly areas. Most importantly enjoy the trip!:thumbsup:
Yeah, AF :) And get a tire patch kit/plug kit and a can of fix of flat. I know you have a spare, but what if. Its just peace of mind :D
Make sure the spare wheel winch is WORKING and you can get the tire off, make sure it has enough air too. A spare serpentire belt and breaker bar to change it or put a new one before you leave ($30.00)
Check the map for areas with potential spots to run out of gas, like long stretches of uncivilized land, don't know where you're headed though, so you may not need to worry.
1 - 8 of 8 Posts
