My 2006 Trailblazer master power window conrtol and door lock switch does not work. the switches on the other doors work fine. I replaced the control panel and still no functions. I wired the window motor direct to battery it worked. Checked all fuses they are fine (both back seat and under hood) and all relays. I have power going into 4 prong plug in driver side on orange line. Have cont on all wires in door between connectors. Any suggestions would be great. I posted in wrong forum earlier and can not figure out how to delete that one
I know you said you checked the relays, but that really sounds like a relay issue. The front and rear door controls are on seperate relays. If not a relay, I would check the mounts for the relay, maybe you have a loose wire. You may also check to see if you have power flowing threw the fuses while in the fuse box.
had similar problem
You say you replaced the master switch panel, right? OK, you may need to have it programmed (dealership) if you bought from salvage yard or elsewhere. I would check and see if the master switch you bought is from an '06 or not. Similar switch panels were used from '02-'06, but unless the one you got is FROM an '06, you'll probably hafta have it reprogrammed. Had same issue with my '02. Dealership wanted $293 for new one + $80 to program it. Bought one from local salvage yard, FROM an '02 TB, and didn't need to have it reprogrammed. It just worked. 50 bucks. Hope this helps some.
