1 - 3 of 3 Posts
So I've lost all power steering in my 2007 TB LS 4.2. I found the leak on the rack and pinion where the pressure and return lines connect to it. Looks like it I just need a new seal. The problem is that the bolt holding the lines in place is stripped and needs replaced. Does anyone know the correct size of that bolt?
Just had the same problem and was hoping there were some good tips to get the stripped bolt out. Any recommendations?
I ended up having to replace the entire rack and pinion. My leak was worse than I thought. It was a process to do in my driveway but it was worth it.
1 - 3 of 3 Posts
