1 - 3 of 3 Posts
2003 gmc envoy_slt_xl
As the title states, my power steering cooler started to leak. I was wondering if anyone has bypassed this; or how hard is it to change. Any info would be helpful as it is leaking pretty bad.
Thanks in advance:thx
not sure about the 03 but on the 06 this was a recall so maybe for you too but other than that i have no idea b ud hope that can help a little bit
It's pretty easy to replace. Put a drain pan under the end with the hoses. Disconnect the hoses. Remove the cooler (two bolts). Reverse the procedure to reinstall. You may or may not have to remove the bumper cover. I would change out all the old fluid, depending on how much you replaced.
1 - 3 of 3 Posts
