1 - 8 of 8 Posts
I changed the spark plugs, made sure the gaps were all right, cleaned the throttle body while in there (made sure I paid close attention to the sharp edges, thanks to those who suffered to tell us to beware), now my gas mileage has gone down considerably. Any ideas?:bonk:
Figure I'll be the first person to say that you should (if you didn't already) disconnect the negative battery cable for 30 minutes to reset the computer's adaptive settings.
First question is did you replace the plugs with AC Delco or an after market brand? - The I6 doesn't seem to like after market plugs very much.
Secondly, when you verified the gap on the plugs, you didn't attempt to adjust them did you? - The iridium plugs should NEVER be re-gapped. The gapping process can actually damage the plug and cause loss of power/performance or fuel economy. (Its a very thin coating on the plugs that is easily damaged).
How does it run other than the fuel economy? Could it e a batch of E10 or some other cause?
I used the AC Delco iridium, no I just placed the gap tool next to them to make sure they weren't bumped in transit. I did not try to re gap them. The negative cable was disconnected for a couple hours while I replaced the plugs. Several stops in the process. Other than the gas mileage it runs great, no more hesitation or missing apparent. I ran some Lucas through it. I cannot find any gas around that is not 10% ethanol. I will see how it does once the tank with the lucas goes through. I will check back periodically. Thanks
It could be possible lazy O2 sensors. Only way to see that is to hook up a scanner. Also hows the air filter looking? Or lastly it could be that troublesome leadfoot I hear about.:woohoo:
07Blazer man: Hooked it to a scanner, no codes pulled. Air filter changed about 5K ago. The lead foot is not a problem, (pawpaw driving, sorta) I think (at least I hope) it is bad gas. Will know more when I am done with this tank. Someone mentioned a possible fuel filter issue, checked it out, still have the original after 135K miles. Could this be a possibility?
even if its not the issue--- change it.
Theyre only about $20 I think.. And very easy to change on the early Trailvoys
Just to clarify not a scanner for codes but a scanner that shows realtime data of the O2 sensors. You can have a lazy O2 that doesnt throw a code but will rob mpg. Good luck.:)
1 - 8 of 8 Posts
