Long time reader, first time posting!
I recently changed the spark plugs and wires on my 2008 Saab 9-7X as I rolled over to 103,XXX miles and was trying to stay up-to-date with service. In the process of changing the plugs, my #2 plug (passenger side front) threads got messed up due to trying to access the plug (from the wheel well). I was able to get the plug back in and drive it a bit. Driving it like this caused constant misfires on cylinder #2 when accelerating. Since this is my daily driver I got a bit scared of reaming/tapping the hole to avoid cross-threading so I took it to a shop to have them look at it. In getting the new plug installed I'm worried that I may have caused the problem by attempting to insert the new plug slightly off-axis.
The shop's machinist was able to clean out the threads and got the new plug further in than I was able to get the plug. It is not all the way in (short by about 1-2 threads), but it holds torque and runs fine at speed. However, at idle it runs rough (particularly on a cold start)and throws a P0302 misfire code if left to idle too long (3+ minutes) without moving. When the engine is above about 600RPM it seems to also run fine. When left to idle (about 500+/- RPM) I can hear a slight hissing sound with the hood open.
I am thinking that it could be a vacuum leak coming from around the spark plug threads. Would this be possible? I was thinking about trying the Permatex black gasket maker cream on the upper plug threads but I cannot seem to find anyone having either had this problem or attempting my fix. Any thoughts?
Thank you to everyone who has contributed so much to this forum over the years! This is the first time I have not been able to find an answer already posted.
