Similar here. 2003 Envoy, 115,000 miles, mostly for camp trailer, or when my wife and I have to go in two different directions. I'm retired.
check the linkage where it hooks to the side of the transmission. The cable snaps onto a ball on a lever on the side of the trans, and they are known to wear and get "sloppy" and to pop off of the ball. If it's the case, you can manually move the lever under the truck to match the cable and "pop" it back on. It will, however, eventually pop off again, so you would need to get the cable looked at/replaced. It could have done the same thing in the center console, but it's not as likely as under the truck (for obvious reasons)94,440 miles (bought new in 2003).
But just today my automatic shifter slipped out of gear while trying to reverse and it would not go back into any gear. I was able to put it back at the park position, but the transmission stayed in drive. So I took the key out, then my shifter locked in the park position, and would not unlock again (even with both the ignition switch turned to the unlock/on position and the brake pedal depressed). Now I can't start the car because the transmission is in drive, but the shifter is locked in park. I don't know......Murphy's Law I guess????
2002 TBL here. 324,000 Miles. Bought it with 40K miles.Trying to justify the new tranny in my 04 TB, with 240k miles ... looking around the internet i see quite a few still on the road at 200 - 300k.
How many miles does your TB have and what major repairs have you had to do?
This one, before this transmission rebuild, has only wanted ware parts, nothing else major. Best rig I've ever owned, from a maintenance perspective.
FYI ... complete rebuild with torque converter and upgraded parts cost me shy $3k.
Our 04 Envoy has close to the same mileage . We just had new tires put on . We bought it from a lot that got it from the original owner . That owner kept the rig up and it definitely shows . We don't have a problem running from northwest Michigan to south Texas and a lot of every day in between and then back again . Done that since we bought the rig and don't plan on stopping anytime soon .04 238k and counting
just put new tires on it,, hoping to get to 300k, but we don't let it get too far out of town these days, use it mostly for short trips around town and utility vehicle for being a landlord/ part-time groundskeeper/part-time maintenance guy
replaced just about everything but the engine itself
I have 4 of them 265k on one 195k on my daily wife's has 165k and daughters has 145k. Best engine gm ever put in a blazer. Super dependable and reliable and easy to work on.Trying to justify the new tranny in my 04 TB, with 240k miles ... looking around the internet i see quite a few still on the road at 200 - 300k.
I wonder if this 4.2 is a good substitute for a 4.3 in a C or K truck?I have 4 of them 265k on one 195k on my daily wife's has 165k and daughters has 145k. Best engine gm ever put in a blazer. Super dependable and reliable and easy to work on.
