1 - 20 of 21 Posts
Im getting ready to change out the Rear Differential fluid on my 03 TB and need advise on what synthetic 75w-90 axle lubricant to get..its 2wd and dont have the g80 rpo code..i was leaning towards Royal purple,or Amsoil severe gear:undecided..any suggetions ....:thx:thumbsup:
Amsoil is what I put in soon after passing 100,000
did u put in amsoil sever gear or amsoil long life??:undecided....and would it matter if i put in severe gear even though im not 4x4:confused:
also which brand meets gm approval or the gm spec??
thanks trailvoy!!!
2 yrs ago when I replaced the fluid- I emailed Mobil 1. their response was that their Mobil 1 gear oil DID NOT MEET GM specs and to acquire the lube thru the dealer.
Amsoil did meet GM spec. I dont recall if Royal purple did....
I created a HOW TO CHANGE your differential fluid thread with pics. search for that..
has images like this...
does anyone know if royal purple meets the gm spec??:confused::thx
Would it matter if i put in Amsoil Severe Gear even though im not 4x4:(????
Also do i need to add anything to it like limited slip additive or anything???:undecided
or
Do i just pour in the 2 quarts and im good to go:woot: im at 114,00 miles by the way if it matters:hissy:
:thx:thumbsup:
or
:thx:thumbsup:
The axle is the same 2wd or 4x4. Amsoil and Royal Purple both meat GM specs and we don't have real limited slip axles, so no additive is required. Having said that, the RP bottle says an additive is in their gear lube.
is 2 quarts correct??:worried:
so how have you guys liked royal purple???
im leaning more towards severe gear but if royal purple meets the gm spec i go ahead and get it since its easier to get
but how about some reviews on r.p first :thx:thumbsup:
chevy
I have had Royal Purple in both front and rear differentials on my 4x4 LTZ now for about two months. Nice and smooth. No issues.:thumbsup:
is 2 quarts correct????:undecided
The front diff is 2.6 pints. The rear is 4 pints or 2 quarts. Trailblazin23 has 2WD.
According to my manual, in the L6
the front differential is 1.7 pints
the rear differential is 3.6 pints
The 5.3 rear differential is 4.3 pints.
Discussion Starter · #17 · (Edited)
So has anybody had problems using amsoil severe gear or royal purple max gear???
Amsoil posted this about severe gear on there website: AMSOIL SEVERE GEAR® is compatible with most limited slip differentials. If limited slip differential chatter occurs, add AMSOIL Slip-Lock™ friction modifier additive.
VS.
Royal purple max gear 75w-90 no additives required it already has it in it
which one do i get???????????????????
Discussion Starter · #19 ·
VS.
which one do i get??????????????????? :undecided:undecided
THe '03 must be different than the '05. And IIRC the V8 has the 8.5" diff.
VS.
Seems to be a horse apiece. Both are good. Pick one and go for it.
the haynes manual says the rear diff is 2.6 pints
I can only say what my owners and service manual say for a 2003. 2.6 Pints front and 2 Quarts rear. In the end it will be what ever fills the differential to with-in 1/4" below the bottom of the hole.
1 - 20 of 21 Posts
