1 - 6 of 6 Posts
2002 Trailblazer
P0014
P1515
P1516
P0132
P1120
P1220
P1221
replaced camshaft sensor,TPS, throttle body
reduced engine power light comes on
possible short caused by the fan clutch.
how quickly does the problem arise after resetting the computer?
could try unplugging the fan, resetting, and seeing if it comes back, providing it's fast enough that you don't overheat first.
A quick search will help out with quite a few of those and what to do :coffee
Just type in the code at the bar above and you will see links to other threads that people put up with the same problem and what was done.
I did a Google search and these are the codes that came up prior to my mechanic replacing the TPS, throttle body, camshaft....it ran well for a week then the codes returned.....STOMPED!!!:(
1 - 6 of 6 Posts
