1 - 19 of 19 Posts
Greetings,
I just acquired a 2007 TB LT 4WD with the 4.2. (I hope I put this in the right place).
I was planning on placing my Garmin GPS on the windshield via the sticky suction cup that comes with it.
Instead of using the cigarette lighter outlet, I would like to hard wire it to a more permanent location in a fuse block.
I looked in the panel by the dashboard on the driver's side, but there are no fuses there.
There is a fuse block under the drivers side rear seat.
Would it be good to wire the GPS in that location?
If so, which fuse should I use?
I would like the GPS to turn on/off with the key.
The cigarette lighter sockets are hot all the time on my truck.
Thanks in advance.
'05 Chevy TB EXT
Be Ye very careful from where you attempt to tap into electrical circuits --- the computers won't like you.
.... and keep that 12V test light out of there! You can load down a 5V circuit and do a lot of damage.
'05 Chevy TB EXT
If you figger out where in a TB to put a GPS -- let me know where I can mount a Johnson 4x4 speaker .... ok?
2007 chevy trailblazer_lt
Greetings,
Thanks in advance.
I put my gps on a mount that attaches to the ac vent, works great there, easy to plug into the power outlet
This is what I was looking for....
Not yet...been working on other issues. At this moment it is in a transmission shop. I was told it has a P0478(?) code. Waiting for an assessment to see what it needs.
'05 Chevy TB EXT
How does a P0478 code, which means that there has been an abnormally high voltage reading from the exhaust system back pressure control valve circuit ... comport with a bad transmission? .
I just got it back from transmission place. Also has code P0948. I was told needs a rebuild at cost of $2700.00.
Wife wants me to dump it
1 - 19 of 19 Posts
