1 - 7 of 7 Posts
2002 olds bravada
if its the bulb i'm thinking it is, then its a 194. but not 100% sure.
i know 194 is the little one but then theres the other one behind the amber
The OEM bulb is a 3457, but I believe you can also use a 3157 bulb if you shave the tabs off the side. (that is, if it's the same as the TB.)
3157 LEDs are a lot more common. I've had a set of Silverstar 3157's in my parking lights for the past year with no problem. With a little trimming they fit right in
Any time you need owners manual info, it is in the drop down menu at the top of the page under resources. It takes a while to down load.
1 - 7 of 7 Posts
