1 - 3 of 3 Posts
2007 chevy trailblazer_ss_3ss
Does the PAC AOEM-GM24 get connected behind the headunit or right at the stock bose amp?
Also, where are you guys grounding your amps in the rear hatch area?
I'll be adding a 12" RE SE sub and JBL1200.1 wired to the sub at 4ohm.
i grounded mine to a bolt that holds down the seats. but you can also use a tie down bolt, but the best place you can use is the negative terminal on the battery.
some nice equipment, wanna c pics when your done :D
and welcome to the site.
1 - 3 of 3 Posts
