I have a 2006 Trailblazer LS 6 Cylinder.
I am getting a P1516 code after replacing the ignition switch.
Many variables with this code. Try and clean throttle body?
Battery might be a bit low but starts fine. Slightly rough idle.
Checked all connections and nothing loose or obvious.
Any ideas?
Discussion Starter #2 (Edited)
On another forum someone said to disconnect the battery and put it on a charge overnight. The purpose was to do a reset as well as charge the battery. It worked. A low battery can result in a false P1516.
