1 - 7 of 7 Posts
Hello all. I have an issue with my 02 trailblazer running hot. I get an error code P1481 and also noticed that the cooling fan isn’t spinning when the engine is running. I’ve read several posts but none have given a definitive answer to this particular issue. Any help or suggestions are appreciated. Thanks all.
First, inspect the wiring of the electrical connection of the fan clutch
I’m willing I try anything. What parts do I need to inspect exactly? I looked at the top harness on the fan shroud. It looks ok.
Discussion Starter #4
Ok. I will check in the morning. Will I have to disassemble anything? I’m fearing that I need a whole new fan clutch.
There are many videos on the Internet about replacing a fan clutch, please study and then you will understand exactly where to look at the wiring and the connecting plug.
There is a TSB about the wires rubbing through near the fan clutch where the wires come from a connector and enter a plastic/rubber connector seen here...
Also, the pins inside that connection can become loose and not connect reliably. If you have a DMM and know how to use it to troubleshoot this type of thing it's pretty straightforward.
First of all, with engine off can you move fan by hand? It should move freely. With engine running, fan should at least move some because the clutch contains a viscous material that provide a little bit of friction.
1 - 7 of 7 Posts
