well, you can try disconnecting the battery and clear the PCM. see if that helps. worth a try
Question on the reflash. The TSB is 3164A. I have an 04 that died with the REP and SES lights last night. It kicked a P0606 code. Light cleared and it's driving fine now, but if the 04 PCM requires a reflash will they do this for free if there's a TSB for it? Thanks.I thought there was a TSB for the '04 PCM that required a reflash from the dealer? I know PCMForless would not do any Tunes on those PCM's unless it had already been updated :undecided
