Hi All,
So this an update on previous post that I cant find and dont want revive it.
Found out this 03 Trailblazer ext has a now expired GM recall for the gas tanks for a rollover check valve where the fuel filler hose connects to.
If you take it to a dealer or some shops they want to replace the entire tank for this p0442 code that wont go away after passing inspection on all other evap components and lines.
Smoke test the fuel tank.
Purge valve, vapor canister, ect we're all checked and cleaned.
Replaced them and they didnt need to replaced, gas cap ect.
If you look to where the fuel filler hose connects to the tank its sitting on a check valve and that check valve goes bad cracks or leaks from what I've read and watched.
Anyone had similar problems ?
