621 - 622 of 622 Posts
2009 saab 9_7x
Does anyone know, if the air solenoid valve is not working, can this cause the air pump to not work or engage on start up?
Not sure. As far as I know its either the relay or the pump itself. If water is in there, the cold winter temperatures can cause the water to freeze and damage the pump or at least prevent it from spinning. I would wait at least until it warms up above freezing and check it then. And pull the hoses off the pump to drain any water.
dwedge
Hi I have a 2005 Chevy Trailblazer LT EXT 4 wheel drive and I got the code PO 410 secondary air injection system how do I fix this?
