1 - 9 of 9 Posts
got a cylinder 6 misfire code will be stopping by an autoparts store to get a coilpack, will change that first and then go from there.:sadcry:
Could be just the plug. You might consider swapping coil packs first with another cylinder to save the big $$ just in case you have a spare day.
2004 non_gmt360 other
Also could be the injector, injector wiring or plug wire. I have the same issue with my bosses van. From what I looked up there are too many possibilities.
Seems worth it to get the diagnostic and fix yourself -VS- trial and error on a misfire code. :m2:
No such thing on an I6.
Whu ? Sounds diesel. :bonk:
I only have 36000 miles on the odo so I haven't even checked yet. Your'e gonna make me go out in the dark cold rain to check now. Thanks :raspberry
Rules that one out now dosen't it :hail:
dropping it off at dealer on monday will let them figure it out, i changed the spark plugs and moved the coils around, and it still is misfiring. so i'm guessing it must have something to do injectors or wiring?
so the freeze frame on my code reader says there is a fault in fuel system 2, if anybody knows what that is could you give me some info. thanks
2002 olds bravada
fuel related=might be a bad fuel injector. Was there an exact code?
:(so it needs a new fuel injector and also needs a new fuel rail. the rail was bent somewhere along the line, and the gm mechanic can't put it back with it being bent. pretty expensive fix.
1 - 9 of 9 Posts
