I checked for vacuum leaks and it turns out the small cap was missing from the vacuum fitting on the back of the intake manifold allowing a vacuum leak. Not sure when it was eliminated but the vacuum fitting hole on the side of the Air Cleaner Intake Resonator is sealed over. I idled the engine to confirm the vacuum leak and then slipped a rubber cap on the manifold fitting to block the leak. I used my scanner to delete the P0171 code and now the check engine light is off and the car has more power.
In the years before computers an engine with a vacuum leak that big would have run rough and most likely would have stalled at idle.
Do you have any pictures of the port you sealed up? I'll be replacing my intake manifold this weekend in an effort to fix a couple issues.
Hey Tom, I've been battling this code for a long time now. Threw some parts at it. Was going to get a smoke test next. Could you please show a pic of the exact fitting u were referring to?
Discussion Starter #4
Find #23 in the diagram, that is the rubber plug that slips over the nipple located on the intake manifold. Without the plug you'll have a massive vacuum leak.
Really appreciate that Tom. Looks like Haynes. Obviously I don't own one. SO, when I was replacing the Purge Valve today and general inspection of all air related components, I FIND THE PCV VALVE IS OFF THE NIPPLE! CHRIST! It's been like that for 9 I don't wanna say how long) from when I cleaned and inspected throttle body. Must have never made it back on :-( Let's see what happens now with the TC's and the damn computer. ***Trying to clear 0171 & 0496.***
